Modbus values not reflecting in Kepware Quick client
Sri1
We have done a Modbus connection to Kepware to fetch an Energy meter data. The modbus driver is running in an edge PC pushing energy meter data to Keware every 2 secs. But the data is not properly updating in Kepware and has a delay update of more than 1-2 mins(in Quick client).
We cross verified with ModScan(Instead of Kepware) and there we were getting data every 2 secs
We checked with the below senarious.
1) Channel's ScanMode was set to Respect Client-Specified Scan Rate.
2) Changed Channel Scan mode and scan rate to various values (below 2000 ms)
None of these worked.
Sri1
AB_7478123
(To:Sri1)
Greetings,
Unfortunately this is likely not a quick answer and we would certainly want to investigate. If you could create a support ticket through the E Support portal, we can investigate what may be going on.
Kind Regards,
Andrew Black
Kepware
