Set tag value in Kepware from ThingWorx MFG App
JD_8670943
I created tags in Kepware and could configure and read their current values in Thingworx MFG Apps dashboards. Now, I would like to set the value of tags in Kepware from Thingworx Manufacturing Apps, but not able to proceed in this regard.
Please let know how it can be achieved.
hrajpal
(To:JD_8670943)
Why you want to set the tag values in ThingWorx Manufacturing Apps ?
JD_8670943
(To:hrajpal)
This is to demonstrate bi-directional communication between Thingworx MFG Apps and Kepware/PLC. The idea is to send some commands to the PLC like start/stop motor, open/close valve, etc.
slangley
23-Emerald II
(To:JD_8670943)
Hi @JD_8670943.
If you need the ability to control processing of your devices, change a setpoint, etc. , you can manage this through the ThingWorx Platform via Composer.
Please let me know if you have further questions.
--Sharon
If my response has answered your question, please mark as Accepted Solution, for the benefit of others who may have the same question.
