Status refresh in Asset Advisor
md'ambrosio
8-Gravel
I defined the status table and one alert basing the same asset property, e.g. status.
It happens that the alert is immediately triggered as soon the status property value changes, while the status  changes after some seconds (about 30 seconds).
Then for some seconds the Asset Advisor monitor shows the Asset still 'Running' (should be 'Planned Downtime') while the Alert is active.
Is this behavior correct? Many thanks Martina
Hi @md'ambrosio ,
As per the current functionality,  status is calculated using a service based on several properties and evaluated periodically when the UI is refreshed. This is done mainly for performance reasons and it is not real time.
Himanshu
If my response has answered your question, please mark as Accepted Solution, for the benefit of others who may have the same question.
Hi @md'ambrosio ,
Himanshu
