I am using textbox validator widget and when the input is invalid I had given a red colour style definition to the textbox validator property. But when I change the style definition to some other colour, the next time it still appears red (the colour I assigned first). I tried with several style definition but the invalid style still appears the same. How can I resolve this?
Shalini V.
when you change the style definition in composer, sometime because of the browser cache the style still appears withe the old configuration. Can you check if the style changed in the style definition of the widget in mashup builder.
Seb
Seb
