TextBox validator invalid style not changing
  • May 8, 2019
  • 1627 views
I am using textbox validator widget and when the input is invalid I had given a red colour style definition to the textbox validator property. But when I change the style definition to some other colour, the next time it still appears red (the colour I assigned first). I tried with several style definition but the invalid style still appears the same. How can I resolve this?
Shalini V.
Best answer by SebB
@svisveswaraiya_285988
when you change the style definition in composer, sometime because of the browser cache the style still appears withe the old configuration. Can you check if the style changed in the style definition of the widget in mashup builder.
Seb
SebB13-AquamarineAnswer
Seb
HI @SebB ,
Yes, After clearing the cache it works fine.
Thanks.
Shalini V.
