How to restore a file
SM_11089709
2-Explorer
Hi, Is there any option to restore drawing in my workspace, I checked out the drawing from the server and this overwrote the latest in my local folder (there isn't any warning for that!!!)?
2 REPLIES 2
BenLoosli
23-Emerald II
(To:SM_11089709)
Probably not.
You had file abc.drw in your workspace, revision B.4, which you then modified and saved.
A checkout of abc.drw B.4 should not overwrite what is in your workspace.
Going to the server and doing a checkout of abc.drw B.4 should also not overwrite what is in your workpace.
Doing a download from the server of abc.drw B.4 to your workspace will overwrite the contents of abc.drw in your workspace.
lfortner
(To:SM_11089709)
Is this a Model Manager related question ? If yes, and some conditions, there could be some positive answer.
