Assymetric extrusion value entering in both direction?
Ertan_Akbayir
Is there a way to extrude assymetric values in both direction?
No, only symmetric.
Asymmetric only in two steps.
SolidDesigner-20.5 + PE8 + PhoenixPDM + Solidworks + Blender
No, only symmetric.
You don't specify what version of Creo you are using. I am using Creo 4.0
If I create an extrusion, when I've finished defining the sketch that will be extruded, I'm given a ribbon with a number of options (make it a cut, create a surface, etc.
One of the tabs on that ribbon is called "Options". If I select that I have a bunch of methods of doing the extrusion, I can specify depth on what they call Side 1 and Side 2. This is where I would, if I wished, do an asymmetric (in terms of depth) extrusion. Put two different depths for each side, and there you have it.
highway45
(To:KenFarley)
In this part of forum we do not talk about Creo Parametric.
