I need convert .mi file to .dwg scale 1:1, because in annotation the views are scaled and I need convert the drawing in dwg real dimension.
Can someone help me?
Thank you.
Stefano
can someone help me?
thank you.
Stefano S.
According to PTC, convert the views to 1:1 scale before exporting.
I hope this helps.
Tom
Change it manually view the view properties dialog...
Automating this with the integration kit is also doable. Either way gets complicated if you use a border.
I try, thank you.
I write a lisp to convert the sheet in dwg scale 1:1.
I set ConvertMIDimensionsToGeometry to ON because dimension works wrong during the traslation.
;converte i disegni in dwg con viste scala 1:1, utile per esportazioni cad-cam, taglio laser, etc
;necessita d'impostare il parametro "ConvertMIDimensionsToGeometry ON" del file DXFDWG.CON e per questo ne ho creato uno dedicato.
(sd-defdialog 'SntDwg-1.1
:module "ANNOTATION"
:dialog-title "Converti DWG 1:1"
:toolbox-button nil
:ok-action
'(if (SD-AM-INQ-DRAWING-NO)
(sd-call-cmds
(progn
(setq dwgname (SD-AM-INQ-DRAWING-NO))
(setq scale_sheet (sinteco-string-to-number(sd-am-sheet-struct-scale (sd-am-inq-sheet (sd-am-inq-curr-sheet))))) ;convert string to number
(AM_SAVE_SHEET_MI :SHEET (uib:get-file-manager-objects) :filename (format nil "c:/temp/~a.mi" dwgname) :overwrite )
(SD-SYS-EXEC (format nil "~a/dxfdwg/scala1.1/dxfdwg.exe -m c:\\temp\\~a.mi" oli::*ci-percorso-pers-sinteco* dwgname))
(am_drawing_delete :dwg :YES)
(AM_LOAD_ANY_MI :ENABLE_WARNING :off :FILENAME (format nil "C:/Temp/~a.dwg" dwgname) )
(am_sketch_resize :sketch "1/TOP" (/ 1 scale_sheet))
; (if (<= scale_sheet 1) (am_sketch_resize :sketch "1/TOP" (/ 1 scale_sheet)) (am_sketch_resize :sketch "1/TOP" scale_sheet) )
(AM_SAVE_SKETCH :SKETCH "1/TOP" :FILENAME (format nil "C:/Temp/~a.dwg" dwgname) :OVERWRITE)
(system(format nil "del c:\\temp\\~a.mi" dwgname))
(system(format nil "del c:\\temp\\~a.log" dwgname))
:failure (sd-display-warning "Errore in conversione")
:success (oli::undo :NUM_STEPS 1)
