2015 FIRST World Championship Creo Modeling Challenge #6 - Production Assembly Drawings
sm
1-Newbie
1-Newbie
Creo Parametric CAD Modeling Challenge
For this sixth Creo Parametric CAD modeling challenge, you will be creating a detailed drawing of a complete assembly model. You need to know basic Creo Parametric drawing capabilities, along with some advanced capabilities to complete the drawing. It is a complex drawing to create and you will need to master Creo Parametric drawing annotations to complete it.
HINTS
  • Use a BOM table to identify all the components in the assembly
  • Use BOM Balloons to identify all the components in the drawing views
  • Use Snap Lines and Cleanup tools to organize and arrange items
  • Use the attached FTC robot or use your own assembly
  • Make sure you have configured Creo with the "Schools Configuration" to access formats, notes, tables, etc.
Sample drawing courtesy of FRC525.
Extra Credit
  1. Try using BOM Balloons with QTY
  2. Add custom parameters to your models and show them in the BOM
  3. Use detail views, cross sections and other methods to describe your model as accurately as possible
0 REPLIES 0
