Creo 5.0 Crashing
chandrasubba
Creo 5.0 Crashing
I am having Creo-5.0 crash very often. The error in the traceback file is "Exception EXCEPTION_INT_DIVIDE_BY_ZERO has occurred in the thread 9536"  Full file is attached.  Any thoughts on what may be causing this.
yeah, i have the same problem. creo crashing out of nowhere.
I often have it, when i use the touch display to either navigate through the tree or rotate the asm.
1.]
Creo crashing can be caused by graphic drivers.
Try adding graphics win32_gdi option into config.pro file.
If problem disappears, install different version of graphic drivers (you have to experiment to find the right one).
2.]
In the past I also met situation when Creo crashing was caused by mouse drivers.
3.]
I have never seen managing Creo via touch screen.
Martin Hanák
