I am trying to install creo 7.0 for students. After installing i tried to open creo parametric but recieved this error:
There is not a lot of information about what is wrong with the license.
I used this link for download:
Here I could open a .pdf and found this license code: BK700908EDSTUDENTEDUNI
Then i used this in the installer and it created a license (name : BK700908EDSTUDENTEDUNI_license.dat)
This file is uploaded with the post.
Since this didn't work I also tried to use a license that was send to me by email.
(name sw_license_email_4990554.dat)
Both don't work. Then i have also tried to recieve a license via k12 students with similar results.
In the installer the codes are available but they don't work for creo parametric.
Can somebody please help?
1.]
In Windows look for active network card associated with MAC address 5C-87-9C-A4-46-D8.
2.]
Edit <Creo_loadpoint>\Parametric\bin\parametric.psf file - replace 2 original files with two following lines.
ENV=PTC_D_LICENSE_FILE-=C:\ProgramData\PTC\Licensing\BK700908EDSTUDENTEDUNI_license.txt
ENV=CREOPMA_FEATURE_NAME=CREOPMA_Student6 ()
1.]
2.]
please make it more clearer and in a simple way, I want to follow your procedure but couldn't understand , what do you want to say?
