Never mind
Buk
Never mind
Too simple I guess.
dradakovic
7-Bedrock
(To:Buk)
Buk
(To:dradakovic)
@dradakovic wrote:
Dear Buk, You can use the Help System inside Creo Parametric. http://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/part_modeling%2Fsketcher%2FTo_Control_the_Display_of_the_Grid.html Regards, Dusko
I did find that. Unfortunately, none of it seems to apply to the version of Creo v1, that I'm trying to use; and I couldn't work out how to get to the v1 documentation.
In any case, I've downloaded v3 in the hope that it:
1) is more accurate in its drawing than v1.
2) doesn't try (and fail) to install some viewer every time I start the program meaning I need to start it 10 minutes before I want to use it -- which is just painful.
3) That it doesn't consume half my machines memory starting 12 different executable, most of which seem to serve no purpose than to occupy memory, but parametric.exe won't run unless they are?
4) Less invasive. What information is QualityChecker sending to you?
3)
