Problem with the downloaded zip file
SOLVED
Newbie
I've downloaded the "MED-100WIN-CD-390_M070_Win32-64" zip file, twice, from the website url https://www.ptc.com/appserver/auth/it/esd/academicFree.jsp . I face the same problem once again. The zip file is said to be incomplete. Here is an image of it when i try to extract it.Capture.PNG
Please help me with it.
Thank you
Tags (1)
Re: Problem with the downloaded zip file
Hi Deepak,
It's possible that the zip file isn't complete because your antivirus or something else is blocking it. What is the size of the downloaded file? Also, have you tried using a different program (such as 7zip) to unzip it?
Chris
Hi Deepak,
Chris
The downloaded zip file should be approximately 4.24GB. It appears that yours is not.
Welcome to PTC Academic!
