How are you doing test simulations in Creo 2.0, because when we open up PTC Simulate it says we do not have the proper license. Is there any other way to simulate in PTC Creo 2.0 or another softwear?
The Student edition of Creo does not include the full Simulate license but does include Simulate Lite. The full Simulate functionality is not required for the 2014 RWDC.
Also, it should be noted that you start Simulate Lite from inside of Creo Parametric. Open a part and then from the Applications tab, click Simulate. You can remove the Structure, Thermal and Simulate icons from your desktop.
Adam
