It appears like old items of the Jive forum are being moved to the Lithium forum (at last?).
What's bad about it is that these items, dating back to 2012 and so, are on the top of the list as if they were entered today. This disrupts the chronological flow of discussions.
Is there something that can be done about that?
Hi LucMeekes,
Thank you for letting us know about this! There is a way to fix this issue. Can you let me know which old posts you are seeing at the tops of boards using the "Notify Moderator" feature as you come across them?
PTCModerator
