Double post this morning
SOLVED
Sapphire I
This is a test to see if the community is experiencing double posts this morning. I read it on someone else's post and on the humor post in PTCooler.
https://community.ptc.com/t5/PTCooler-OffTopic/2020-05-22-Friday-Humor-Over-designed/m-p/667431#M532
Re: Double post this morning
  Hi, there, Community.  Following up, double posting was resolved last Saturday.  Thank you for drawing our attention to this issue.
9 REPLIES 9
Here is what I am seeing:
I am beginning to think this might be some some sort of setting. Is anyone else seeing this, because I am evening seeing it in old posts.
I made a post early this morning, and it turned into a double post.  It's under Assembly Design.
When I kudo'd one of them, it kudo's both
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
Do I get two kudos then....   😉
I just got new glasses this week so I'm 100% positive that you guys are seeing everything thru my new glasses...everything is doubled up. Its the only possible explanation!
Steve Williams
Hi Community thank you @Dale_Rosema  for bringing this to our attention.  I think there was some configuration changes yesterday.  I am looking into this as I type this message!
Wow - super multitasking.  🙂
Thanks for checking into it.
