This panel included Windchill Admin experts from Cummins, Enerpac, and Raytheon who shared how each of their companies applied strategies to overcome common challenges such as project constraints, solution implementation processes, end-user adoption and more to achieve their business goals.
Hi Toby,
are you sure that attached presentation is the correct one?
I can't see in it what you wrote in the description of this document.
I will double check Marco - thank you.
Toby
Hi Marco - this is correct
Toby Metcalf, it's not. This is what I see on the LiveWorx page:
The PDF listed, "177_NASAGlennResearcCenter_Bailey", is completely different. (I'm looking at it right now.)
The PDF you're showing is from Windchill Roadmap:
