I am using the arduino weather app project to connect with thingworx. On the serial monitor I can see the values of temperature and humidity been updated. but they are not updated on the thingworx . (I checked by refreshing). i went through posts in the community and got to know about the things to be checked and unchecked in the platform subsystems. I was working on the academic instance. I was unable to check and uncheck. it flashed message saying u are not authorized to do so. then i launched the thingworx foundation server 30 day trial edition. i could easily check and uncheck in platform systems. but for the server name when i checked the url in the address bar it just showed me http://52.198.165.187/Thingworx/Composer/index.html .now as per the tutorial if my link is https://academic.cloud.thingworx.com/Thingworx/Composer/ then i can use the server name as academic.cloud.thingworx.com so from the above url i was just confused as to what should be the server name. i tried http://52.198.165.187 as the server name. icould still see the updated readings on serial monitor but on thingworx it was not updated. i tried 52.198.165.187 then the serial monitor showed the message that the server could not be established.
my question is my foundation instance shows http://52.198.165.187/Thingworx/Composer/index.html this url. wha should be the server name? and if there is anything more to that. i have checked the property variables the service their case senstivity.
I have used dht11 sensor and changed the code accordingly
