Hey! I bought the 1-year student license (PTC Prime 😎 this week, but I can't activate it. License request failes. See screenshot.
What do I do?
PTC Prime 8
1.] What Host ID is included inside license file ?
2.] Run ipconfig /all > ip.txt command in Command prompt window and upload ip.txt file.
The host ID don't match
Please send ip.txt file
Is that the notepad-file?
it look like you do not understand me. Just do following steps:
Sorry, I don't get it. I've typed the command and pressed enter but nothing happend.
the command created ip.txt file in directory.
@AK_10584883 wrote:
Ok. See the attachments for ip.txt file
1.] ip.txt file does not contain physical address A8-7E-EA-E9-C6-3B (included in license file)
2.] your laptop does not have LAN connector, only WiFi network card is available
Please disable MAC randomization, reboot laptop, generate new ip.txt file and send it to me.
https://support.boingo.com/s/article/How-to-Disable-MAC-Randomization-in-Windows-10
@AK_10584883 wrote:
It is turned off.
according to https://www.ptc.com/en/support/article/CS68726 article, you can:
Request for a license manually by providing Mathcad product code and physical address of network adapter using web case logger. The license file will be sent via E-mail.
Web case logger URL ... http://support.ptc.com/support/mathcad_supportCenterSingleUser.htm
Send them MAC address of your WiFi network card ... EE-43-84-7D-C6-79
Thank you. I've tried to send a request.
I presume product code is the same as licens key?
And MAC adress the same as host ID?
Attachments shows immediate respond.
it looks like your request was rejected.
Try another method ... send email to academicsupport@ptc.com
Describe your request, add Mac address and the product code.
