Creo 1.0 license utility problem
ptc-4936073
Hi everybody !
It's now two days that i search all the way to find a solution to install Creo 1.0. I want to install the school version i'm following the process that the help gives you. The trouble is that when i'm downloading Creo 1.0 License utility i can't make it run my computer show me two possibility :
The installation is made correctly (if i press it nothings happen)
Make a reinstallation (if i press it well nothing happens too !)
I'm getting a bit crazy because then i can't create my PTC account and then i can't use it,
I need it for my school project so if you can give me some advice i would be grateful !
Have a good day and see you soon !
Magdaléna
This is most likely due to your virus or firewall protection.
Instead, use the instructions in this document to install the Student edition of Creo 1.0: http://apps.ptc.com/schools/references/install_creo1_student.pdf
For the fastest response to your issue, your best bet is to fill out the PTC Academic Support Form.
Hi there
one simple question. I filled out the document and click submit a few times, but in every case the page generates itself back to the empty mask.
Is there a kind of information given, that the submitting was clear, or is it quiet normal, that no further information is given?
Thx a lot
