Been having issues with drawings in the student edition of Creo 10. Apparently none of the symbols work. I get an error message saying the files are incompatible for my version of creo.
@TL_10579918 wrote:
I don't have a setup.exe file in any of my PTC or creo folders.
you can try using Parametric\bin\reconfigure link to reconfigure license.
Do not forget to move all license files from C:\ProgramData\PTC\Licensing directory before you start reconfiguring action.
FYI setup.exe is available on installation media.
There are some issues with some of the symbols and templates that are now incompatible with the student edition. Please reconfigure (run setup.exe and choose Reconfigure licenses in an existing installation) and ask all the rest of the students to reconfigure their Creo 10, using the following code: BE100908EDSTUDENTEDK12
~Alex
Thank you for the advice. I must have done something wrong as it did not work. However I did uninstall and then re-install the software and that seems to have fixed the issue. Thanks again.
This did not fix the issue
