Creo 3.0 Installation problem
bchauhan
7-Bedrock
Hi Guys.
Good evening.. i need your help.. well basically, teacher want to me to install Creo 3.0 from MED-100WIN-CD-400_M190_Win64 onto all student machines.
Now i have read all the instruction on how to install Creo 3.0, when it comes to section where i have Run - setup-schools.exe and i have right click the file and select " Run as Administrator" - Successfully done
then i click install new software then click Next - Successfully
then i accept the licence agreement then click Next - Successfully
then i cannot see any list of Creo programs in the box as its all white box.
What can i do to get to see list of Creo Programs which i can install or not etc.
Please advice me please.
Look forward to hear from you soon.. Thank you
Kind Regards
Bhav
6 REPLIES 6
That is the guide for students and in order not to confuse them we tried to simplify the process.
In order to get access to the installed packs, please use this guide:
http://apps.ptc.com/schools/references/install_creo3_schools_premium.pdf
The product code that you will be using is:
BE400407EDSTUDENTEDK12
Let me know if you have any issues!
Alex
Hi Alex
Thanks for the Licence key for K-12 .. unfortunately the key doesn't work.. I have tried use " Run as Administrator" still doesn't work.
Please see attachment of error message.
Please advice me what shall i do next.
Kind regards
Bhav
Make sure that you type the code in, so no space after is getting in the field.
If you still get the error, please hold the mouse over the error red message and tell me what it states.
Alex
Hi Alex,
Please find attachment of error message when i mouse to error message
" You have reached the maximum number of license requests available for your product type"
Hope this helps you.
Bhav
Please check the PM from me and answer it so I can provide direct support.
Alex
Hi Alex,
Its stated that
Bhav
