Creo Elements/Pro Student stopped at 2% during installation.
cmartinez
So when finishing the download/install process for the program the download shows to be 100% done BUT the copy files bar is stuck at 2% and doesn't change at all. When I tryed again I got the same results. Can anyone help me solve this probelm. I really need help on this one.
3 REPLIES 3
Hi Carlos,
You are trying to install using the install from the web utility. This will pull files down during installation. If there was a network glitch, it might be freezing at that point.
What I recommend is to download the full media from the link below.
Creo Elements/Pro Student Edition
Once you have it downloaded, extract the zip file and start setup.exe to perform a fresh install from the local machine.
mark
I purchased the student edition by journeyEd 5.0, I have problem downloding it freeze at 2%.
Jimmi
You can use "Free Download Manager" to download the package.
