I should also add I could not locate the buw file within the extracted zip on my second reinstall.
Try following the steps in this wizard - "Guided Licensing & Installation Troubleshooter": https://www.ptc.com/en/support/creo-admin-troubleshooter
Hello @MJ_14453464,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
