Delet Old Version
ItzikBenShabat
7-Bedrock
Delet Old Version
I am running out of hard drive space and i wanted to know what is the best way of deleting old versions of parts or assemblies? (for example it saves prt.2 and prt.3 and the latest is prt.4, so i only need the latest)
thanks,
Itzik
There are Two methods.
Method 1: You wish to delete older versions of a PARTICULAR part or assembly
File --> Delete --> Delete Old Versions
Method 2: You wish to delete ALL older Versions of all the files present in Working directory
Window --> Open System Window [opens a system window]
Type "Purge" and enter.
Type "Exit" to exit from the system window.
