Screen shot attached. This page appears I then change the URL to https://plms4schools.ptc.com/precisionlms/ which immediately reverts to the original , Schools LMS : Login and I can login as usual. If I then save that URL as a home page the next time I load IE 11 the same error appears. Any clues anyone?
JOHN E FORTH, it should be working now. There was an issue with one of the NFS mounting scripts following a maintenance weekend, but it has been corrected.
