I have Downloaded Creo 5.0 Student Version Done the installation as per install_creo4_schools_standard Document using setup.exe, got the License by login to my Account During installation, After Installation Encountered Licence Request Failure, Tried to Reinstall the Software Facing the same issue, Even Installed setup-schools.exe Still the Problem Remained, Kindly Help
We are sorry for this issue, the web team did not change the installation guide for Creo 5.0.
Please use this instruction:
http://apps.ptc.com/schools/references/install_creo5_schools_standard.pdf
Alex
Alex
It Worked, Thank you, Sir, for the support
