Error in licensing Creo 6.0.2.0
MS_9460692
I have installed creo and added the license file which was given to me from my university. When i open creo, it says license request failed for feature and 7788@DESKTOP- 1987DS8: (-8) Invalid (inconsistent) license key.
Warning: (-96) cannot connect to server.
What should i do to resolve this issue.
5 REPLIES 5
you have to understand what is inside license file. If you upload it I can tell you what I can see.
Martin Hanák
I have attached the license file.
  • your license file contains floating licenses for MAC address B8-2A-72-BF-65-16
  • please check if your PC contains network card with this MAC address and that this card is enabled and active
  • to access floating licenses FLEXnet license manager must be installed
  • your licenses need FLEXnet 14 or higher
  • please check what version of FLEXnet is installed
  • look for following services
    • FLEXlm server for PTC
    • lmadmin_ptc
  • run ptcstatus.bat from FLEXnet installation ... output information contains FLEXnet version
Martin Hanák
I attached the ptcstatus.bat. Can you please look at it and tell is it working or not and what else should i do?
ptcstatus.bat output tells us that FLEXnet license manager is not running.
Please upload:
  • license.dat file mentioned in ptcstatus.bat output
  • log files located in FLEXnet logs sub-directory
You can also:
  • stop lmadmin_ptc service
  • open Command prompt window and launch lmadmin.exe (use full path to launch it)
    • sometimes this command throws valuable error message
Martin Hanák
