Galileo gen 2 board
hjaurkar-2
Galileo gen 2 board
I am working on galileo gen board 2, and doing a project of weather project. The properties are not getting connected to PTC. I am having a issue on the TWC_Agent, while manually running TWC_Agent, it is showing some errors as "Error trying to connect" & "invalid 'connection' header" and "websocket connection failed". If someone has came across these errors kindly share solution
9 REPLIES 9
Aanjan
(To:hjaurkar-2)
Harshal, do you have any proxy server in place?
No, there is no proxy server. But I do have a Wi-Fi router, Will that have any effect?
Aanjan
(To:hjaurkar-2)
I've seen the invalid upgrade error few times, and it has been with connections involving reverse proxy (as it sends back 2 extra headers). Using the latest version of the Edge MicroServer should fix that.
From Where can I download it. the "Edge MicroServer". I have searched the site, i could not find it.
Aanjan
(To:hjaurkar-2)
It is available on the PTC Support site under the Download Center -> ThingWorx Edge Microservers section
I am not having permission to access it can You mail me the zip file of the latest version of "ThingWorx Edge Microservers"
kindly mail me,Screenshot from 2016-03-10 23:00:43.png
email id is "harshaljaurkar@gmail.com"
Aanjan
(To:hjaurkar-2)
Harshal, this would probably have to go through sales. Do you have a support account or do you still have the contact information of your sales personnel?
*Edit*
I'll reach out to someone locally here and see if something can be done.
THanks for your help,
Actually my network had the problem, I tried on my friends network, it is working now.
Thanks for your precious suggestions.
Now I am trying to built the mashup.
Do you know the procedure how to make an image visible and invisible for a certain changes in the parameter??
Aanjan
(To:hjaurkar-2)
Harshal, generally all widgets have a 'Visible' property that can be bound to. You can enable/ disable (or check/ uncheck) that based on your result.
