I'm using Implementer version 12. 4 on IBM i V7R3.
Using the Workbench, with with objects, I checked out an SQLTABL member named TLWBP170SV.
This member contains a CREATE OR REPLACE TABLE TLWBP170.
When I use option 14 to create it, it creates TLWBP170, which is fine.
When I use option 11 to promote it, it fails because somewhere in its process it expects the created object to be named TLWBP170SV.
The question is, how do I rename the SQLTABL member to TLWBP170?
P.S. When trying to select a location for this post, I was unable to see all of the
possible locations until I shrank the display sufficently. Also, there does not
seem to be a location for Implementer Change Management.
