I converted this Mathcad sheet from xmcd to mcdx. But now I've this error it is not calculating.
The file is attached. Please help me if know to fix this error.
please read https://community.ptc.com/t5/Mathcad/How-to-use-Find-Function/td-p/721059 discussion.
As Martin already mentioned, the 'syntax' for a a solve block was changed.
I don't know if it's still relevant after more than a year - anyway, in Mathcad, typing "Given" started a solution block and it ended with "Find", for example.
But in Prime you have to insert an (ugly looking) solve block from the menu to do so.
I think you are better off to ask questions about Mathcad or Prime in the forum here: https://community.ptc.com/t5/Mathcad/bd-p/PTCMathcad
