License not found
  • October 12, 2019
  • 2 replies
  • 9308 views
Hi there!
Just installed the academic version of Creo Parametric 6.0.2.0 but the license cannot be found. I got a license pack via mail and want to know where to put the file in?
Thanks in advance! 🙂
Best answer by MartinHanak
@jousefmrd wrote:
Hi there!
  • launch reconfigure from Creo's Parametric/bin sub-directory
  • in License Identification dialog box in License Summary section enter path to saved license file into Source field
  • finish reconfiguration
jousefmrd1-VisitorAuthor
Hi Martin, is this supposed to be a hyperlink?
@jousefmrd wrote:
Hi there!
Hey Martin!
Thanks for your response. Just checked and there is no reconfigure file as far as I can tell. Does it have a specific name?
You can also simply run setup.exe (from the folder you installed Creo) and select reconfigure existing software in the first tab. This will do the exact same thing as reconfigure.exe, but for all the software parts (Parametric, Direct, Layout...).
Alex
