Lost my student edition of creo and cannot download it again
ptc-5290388
Hi all,
First of I would like to say this should probably be in the university section however no one has posted there in over 2 months.
I'm in my first year of university and did a design module using PTCs Creo 2.0 which meant I was eligible to download it for free, which I did. I was using an AMD based system but wanted to switch over to intel so I could get a beefier processor but that meant I needed a new motherboard, which in turn meant I had to input my product code (or what ever it is that you use to activate the student edition) but I deleted the email over 4 months ago which meant I couldn't use the program.
Is there anyway that I could redownload creo 2.0 and get my activation code again?
hopefully the answer is yes because I really need it for my assignment.
Hi Nathan,
You can renew your license of Creo with the below guide:
http://apps.ptc.com/schools/references/relicense_creo2_student_uni.pdf
Let me know if you have any questions!
4 REPLIES 4
I've moved this discussion into our .
Hi Nathan,
Thank you for the reply. I no longer have any of the phyical files on my PC as I had to wipe my hard drive when installing windows 8.1 is there a way I can get the download again? I have tried applying again but the application page doesn't accept it stating that the user has already applied. I know longer have the e m-ail containing the download either .
Nathan,
Here you are: http://apps.ptc.com/schools/references/install_creo2_student_uni.pdf
Just follow that guide and you should be all set!
