MathCad 12 Student Edition
PhilippTuchel
Dear Sir or Madam, I have recently bought the MathCad 12 Student Edition, but unfortunately it has neither worked on Windows XP nor on Windows Vista properly. First I have entered the Product-Key on both systems correctly and MathCad has been installed. On Windows Vista I have not been able to open mathcad.exe. To activate MathCad I have to open it, right? On Windows XP I have had the same problem besides opening mcad.exe for activation. After double-clicking on mathcad.exe and mcad.exe I have seen a running window, but it has been shut down. What is my fault? I'm looking forward to hearing from you and thank you in advance. Best regards, Philipp Tuchel
Hi Philipp, Can you please let me know where you purchased the version 12 from? The latest version is 14. Thanks, Mark
I have a MathCad 12 Mechanical Engineering CD that will not run without installing MathCad 12. However, because I have 14.0 student edition installed, I cannot access the Mechanical Engineering CD. Is there a way to access without having to install 12? Richard Crowson
Hi Richard, The Mechanical Eng CD is build with mathcad 12. This is why you need to install it before you can use it. It will not work with Mathcad 14. I am sorry. Mark
Hi Mark,
thanks for your reply. Finally I purchased the version 14 which works.
Best regards,
Philipp
