I need some help with setting up the MathCad worksheet that the kids are supposed to use to upload calculations into Creo. I am a newby at this, so any suggestions would be greatly appreciated. Thanks!
I would strongly recommend that you have your students go through the RWDC Curriculum course I prepared for the teams.
http://www.ptc.com/WCMS/files/132347/en/RWDC_HOW.pdf
It goes through the use of all the applications for the challenge. Specifically, there is a primer documented for Mathcad you should have them go through.
In the challenge, we are preparing a number of worksheets teams will be using.
Mark
Hi Lavona,
I am happy to help with your installation. Do you have a series of product codes for the install of Mathcad? I would recommend that you review the installation video for Mathcad. The link is below. If you continue to have issues, please send me an email aat -.
Installing Mathcad Prime 1.0 Student Edition for RWDC
Mark
I have the MathCad installed but I need a good tutorial. I have never used MathCad before and need some help with getting the worksheet put together that the students need to use to do the calculations.
Mark
Do you have to be logged in to the LMS to take these courses. At this point, I am the only one with an account. My students do not have a LMS account yet. But I am working with Adam Haas to get that set up.
So is the MathCad worksheet that will be sent out the one that the kids will use to submit in Windchill with their iterations?
Hello!
Some video tutorials on working with Mathcad Prime 1.0 can be found here (at PTC site "LearningExchange": http://learningexchange.ptc.com/😞 http://learningexchange.ptc.com/tutorials/listing/product_version_id:26
Also, from PTC Academic Programm - "Mathcad Prime 1.0 Primer Tutorials".
