Mirror subassembly
  • January 29, 2011
  • 2506 views
Is there a way to mirror a sub asm in my main asm ?
thanks
    Creating mirrored subassembly in main assembly:
    Insert>Component>Create - select Type > Subassembly / select Sub-Type > Mirror
    Insert new name for your new subassembly > click OK.
    (You can define Geometry/Placement dependecies)
    Select source subassembly and mirror plane. In new window is possible define new-name for subassembly components.
    Complete operation: press OK button.
