Problem in downloaded Zip file
ptc-5475045
I have downloaded "MED-60825-CD-370_M080" zip file from http://apps.ptc.com/schools/references/install_cep_schools.pdf, but will extracting the files, an error is coming saying "file is broken". What are the steps to overcome from the problem.
Tammay,
From the looks of it, you have an incomplete download. The total size size should be much larger. All you need to do is try the download again. If you continue to run into this problem, I would recommend trying to move to a more stable connection.
I hope that helps!
Tammay,
I hope that helps!
