Problem with setting up servo motors to two pin connections
MikkoK
2-Explorer
I've trying to set servo motors so my assembly would move between snapshots. I'm able to move only my lower saft but when i enable second servo motor to upper saft it fails to define them. What I'm doing wrong?
I've pin connections to my frame which is fixed and all the other connections are sylinder and also when bearing connection. I really can't figure this out.
Thank you!
0 REPLIES 0
