Hello!
I installed Creo 3.0. After opening Creo Parametric a web window appears that I can't close, as seen in the first attached image. Also, after creating a new part, the plans do not appear (image 2).
What I supposed to do in this case?
Thank you !
1. To disable embedded browser from showing at start up:
2. Try this one to show datum planes:
@CD_10092461 wrote:
Hello!
Thank you !
the problem can be caused by graphic card drivers. To test this idea, please add following option at the end of config.pro file (temporarily) and restart Creo.
graphics win32_gdi
