Program Freezes During Installation of Creo 5.0 and 4 M030
chris8
2-Explorer
For the last few weeks I have been trying to install Creo 4 M030 on my laptop. Everytime I run the installer it would always freeze after I enter my PTC login details. I tried Creo 5.0 last night and was meeted with the exact same problem.
I have tried downloading the file a few times and this has froze every time. I had 4 M020 installed previously but I have this uninstalled, unless there is something still around from that which is causing it.
I have seen on other posts about graphic drivers being at fault; My laptop has Intel HD Graphics 3000 which has the latest driver installed, along with any other drivers.
I have attached the latest traceback.log file from the installation (version 5) and would be grateful if anyone could determine what my problem is.
MartinHanak
(To:chris8)
1.]
Intel HD Graphics 3000 is very old GPU. Even if it is probably not supported, it should not make installation problems.
2.]
Installator looks into C:\ProgramData\PTC\Licensing directory. Empty this directory before you launch setup.exe.
3.]
Installator looks for suitable network card ... if it does not find it, it can fail.
Installator does not like VPN network card, virtual network card.
Installator is able to work with LAN or WiFi network cards, which are connected to network.
To get a list of all network cards, you have to open Command Prompt window and enter command ipconfig /all > ip.txt ... command output is written into ip.txt file.
Martin Hanák
10 REPLIES 10
MartinHanak
(To:chris8)
1.]
2.]
3.]
Martin Hanák
jogro
(To:chris8)
i have the same problem here.
Installer hangs when i entered the login details.
any solutions ?
greetz joachim
chris8
2-Explorer
(To:jogro)
I have found the problem. I had extra network adapters installed (virtualbox was one of them). After they were disabled the installation continued as normal! Thanks MartinHanak for the help!
jogro
(To:jogro)
i have tried the following but no changes:
deactivated Intel graphics
deinstalles Virus security
but no changes.
MartinHanak
(To:jogro)
but no changes.
chris8 confirmed that the problem is related to network card. Check network card list.
Martin Hanák
jogro
(To:MartinHanak)
no changes, it´s not possible to install the Programm,
I deactivated all Network Cards ( Microsoft direct wifi virtual Adapter, turedo Tunneling Adapter, and the not connected lan Adapter).
Any other Solutions?
MartinHanak
(To:jogro)
what network card is enabled and connected ?
I suggest you to enable and connect LAN network card.
Martin Hanák
jogro
(To:MartinHanak)
i´ve only the LAN card enabled
I have disabled WLAN in device Manager.
The only Network card in ipconfig /all list is the wired lan adapter
jogro
(To:jogro)
Problem solved,
i tried to install creo 5 and followed the Installation guide, step by step.
http://apps.ptc.com/schools/references/install_creo5_schools_standard.pdf
seems like it was a RTFM failure.
THX for help
Greetz
Joachim
Lucas_0212
2-Explorer
(To:jogro)
what was the exactly problem?
I have the same problem with the Creo 5.0 installation.
Greetings
Lucas
