To relicense your Creo after the license expires, you can't use the relicense form the pop up window, as that is only for paying customers.
Process is simple:
1. Run Setup.exe as an administrator
2. Choose relicense existing product
3. Follow the process and insert the correct version code that you used to license one year back.
This will relicense your free student Creo license for another year.
Please note that you can only renew your free Student License until you graduate.
it seems to me that is is necessary to remove expired license file from C:\ProgramData\PTC\Licensing directory before start step 1.
