The installer gets to the point of "Copy Files" and hangs at 2%. Tried to install on my note book and of course I got the message that I had no furthur license files available. Any ideas?
David,
You are having a problem with the Web install, some users encounter this and some don't. The best thing to do is download the entire installation DVD at http://apps.ptc.com/schools/Creo_ElementsPro_Student_DVD.zip.
This is a large download, approximately 3.6GB so unless you have a very fast connection, I would suggest you use a download manager such as Free Download Manager, this will allow you to stop and restart the download if necessary.
I hope this helps.
Adam
The install went better and the application opens, but now I get an error message about the license file "License request failed for feature - Requesting PROE StudentEditions 5...
C:\Program Files\Creo Elements\Pro Student Edition\text\licensing\licensing.dat: (-2) Invalid license file syntax"
Any help on this.
Thanks again
David Campfield
David,
All Academic support should go through our PTC Academic Support page where you can find a solution yourself or if you can't find a solution, submit a support request from the bottom of the Request Academic Support tab.
Adam
I am also having this problem with the academic edition of creo paramteric.
wht i your OS?
