Trouble with my license
so-2
1-Newbie
Hi! So I downloaded the free student version of creo, but I skipped the licensing step. I skipped this step because I could not click on the box to enter my license number. The box was strangely blocked. I was hoping to finish installing everything and be able to go back and input my license info, but I'm not sure how to do that. Can anyone help? Thanks
4 REPLIES 4
nnerpel
1-Newbie
(To:so-2)
I have the same problem, could you solve it yet?
ajoshi-2
1-Newbie
(To:so-2)
Same problem! The text field where we have to insert the license number isnt accessible!
Are u people using Windows? and is it Windows8 or above?
Because this problem wasn't there when I was using Windows 7
MartinHanak
(To:so-2)
Stephanie,
email you request to -
-OR-
enter your request on http://support.ptc.com/appserver/support/academic_case_logger/academic_case_logger.jsp
Martin Hanak
Martin Hanák
Hey guys,
I was having this same problem, but upon reading the install directions a little closer, I found that I needed to run the "setup-schools.exe" install file instead of the standard install file. This install simply asked for username and password, then automatically generated the license in a hidden folder. Try this and see if it works. I still haven't managed to get the software to open on my son's computer yet, but we'll get it figured out.
Good Luck!!!
Scott
