We are FTC team #8521, and we have just finished our season. Now we would like to upgrade to Creo Parametric 3.0 from Creo 2.0. We just have a few questions.
Thank you very much,
Trevor A. Babb
Hard-Hitting Hardware Hooligans
#8521
Thank you very much Mr. Morris!
Is there anything special that needs to be done to connect Creo 3.0 to Windchill? Or are we able to use the same process to connect?
_________________
aliiiiii
It is the same process. If you have already registred Windchill with Creo 2.0, it will show up after you start Creo 3.0.
Is it possible to rename your team's project, if your team's name changes?
Yes, you will be able to do this next week. PTC has had an outstanding issue on the Academic Windchill server trying to complete any change to the details of a Windchill Project. This issue has been recently resolved and will be implemented on the production server this week. I will post an annoncement about it as soon as the update is complete.
