Will Creo 4.0 license also work for version 3.0?
Citon
3-Newcomer
Will Creo 4.0 license also work for version 3.0? I need to know if I can run both versions with the 4.0 license.
MartinHanak
(To:Citon)
Creo 4.0 license enables you to run Creo 3.0, Creo 2.0, ...
During Creo 3.0 installation do not enter Product Code. Instead of it put path to license file into Source field.
Martin Hanák
Citon
3-Newcomer
(To:MartinHanak)
Thank you for your response, a couple quick questions to help me fully understand. So would that be for example port#@hostname or and actual path to the 3.0 license on the licensing server? If it is just the port#@hostname it would be the same for both versions and then the licensing server can tell which licence to hand out?
MartinHanak
(To:Citon)
in case that you have license server managing floating licenses, then enter port#@hostname. That's all.
Martin Hanák
We have creo v2 that has server floating lic.
We are about to get 64bit machines so will be looking to install creo v4, will the lic be ok with this version? or will I have to get a new one?
link for new request if required please
jim
