I have been trying to connect to my team's windchill server and when i go to register the server and put the location link in the window, it sends an error code "Invalid server location. Please change the "Location" field and try again." I was connected to the server using this same link previously and one day it randomly disconnected and started giving me this code when i try to register it again. I uninstalled creo and installed it again to try and get it to work but no luck there.
Any help would be great!
Thank you,
Tanner
Close Creo and brows on your computer to: C:\Users\{YourUserName}\AppData\Roaming\PTC\ProENGINEER\Wildfire
Delete the .wf and after starting Creo add the server.
Alex
