absheik_is_dak9.asm.1
avijayakumar
Hello, I followed the steps that you told me to make sure all parts are on the file. Would you be able to take a look and tell me where the problem is so that I can make a working servo motor and simulate its movement in motor analysis.
1 REPLY 1
sm
(To:avijayakumar)
Abhishek Vijayakumar‌, the attached ZIP only contains the .ASM file. It does not contain all the .PRT files required for the assembly. Please take a look at How to Save a ZIP Archive of your Creo Parametric Assembly? to make sure you are creating a copy of the full assembly when creating the ZIP.
