creo 3.0 agent install error
tburcham
I want to start out by saying I am installing 3.0 on a very old PC.  Creo 2.0 trial ran without issue.  3.0 opens and seems to run OK but after it is open for a few minutes I get the following pop up.  I have uninstalled and reinstalled.  Also, repaired installation.  No change.  Any ideas?  Is it due to browsers out of date? Thanks, Terry
First you should make sure that you uninstalled all PTC Creo 2.0 applications from your computer using Control Panel (also the old PTC Agent).
It is important to read also the requirements of Creo 3.0 (in the installation folder you will find the ReadThisFirst.pdf). It might be an issue with the system.
Please note that Creo 3.0 will not be running on XP.
Alex
Hi
Have you tried to set the path to the agent in the psf file??
You might have a look at this:  PTC Creo Agent error
Had similar issue after renaming folders - solved by adding / correcting this ENV
ENV=CREO_AGENT_EXE_PATH=C:\PTC\CREO3\Creo\Platform\3.67\creoagent.exe
