Hi!
So I'm trying to install Creo 8.0 as a student,, The given product code was accepted and I got the "success!" result. However, I can't finish the installation since the "license server" is not available! Also the file sent by Email was not accepted.
What should I do here??
Thanks in advance!
Already solved..
It was a stupid mistake from my side, I was using "install_license_server.exe" instead of "setup.exe".
Already solved..
