If I try to open Mathcad14 from a user on my computer who does not have Admin rights, I get the following error message:
The only way I am able to bypass this (aside from signing out and logging on as an Admin) is to right-click and choose "run as admin" (I also know how to go into the properties of the exe file and choose to always run as an admin), but I would prefer to avoid this.
Any experiences with this?
Mark,
I haven't got the answer to your problem, but have come across the "admin rights required" problem. When I run the spell checker I can't add words to the English dictionary because I need administrative rights.
There a few ways as you know to get around this problem.
If it’s a work computer get them to give you the required permissions.
If you can log in as an administrator – Just give yourself the permissions – Like I did. J
Not quite the answer you where looking for, but hey problem solved.
Mike
